I've currently got a '90 Tipo 1.4 Formula, shortly to acquire another Tipo of unknown origin (but in better nick/lower mileage than mine!). And by the looks of it, we're going to be driving from London to Mongolia in the new one (using mine as a donor). That's 8,000-odd miles with some hard-going terrain. So, I'd like some advice on rally-prepping the car!
1) Suspension. Raising it a couple of inches would be useful to gain ride height. Is this just a case of changing the springs, or would the shocks need changing out as well. If the prior, can anyone suggest a car we could nick longer springs from that might be compatible sizes? If the latter, ditto. :yum: [edit] I've since read that just boosting the suspension doesn't actually raise the ride height due to the axels still being the lowest thing! Having things a bit bouncier may still be useful tho, and may think about slightly bigger wheels/tyres?
2) Fuel tank: I'm considering roof-mounting it, again for ride height and to avoid damage. thoughts on this? is it just a case of mounting a tank on the roof (which is also going to have a lot of spare wheels/tyres on it) and attaching a hose, or are there more complex things to think about? [edit] Another thought might be to have twin tanks, one in the usual place, and one from the donor car on the roof, with a simple swith between the two. Double the range without stopping!
3) Sump guard: Is going to be in the form of scaffolding planks mounted in a removeable bracket underneath. Is there anything else in the liable to be damaged? I'm not a mechanic, and don't have access to a car lift to have a good look underneath.
Anything else we should be thinking about?
thanks in advance!
Oli
thanks in advance!
Oli
