Technical  Rain sensor wipers
ovy1970
Leeds
Bought a 67 plate Fullback LX 4x4 Auto
The auto rain wipers are not working.
Replaced the gel pad on the windscreen.
Is there a setting somewhere to activate the wipers?
Also is there a setting to activate the lights to come on when you unlock the doors.
Looked through the on screen settings but cant find any vehicle settings
have you got the manuals/document pack with the car? It will almost certainly cover these questions in the book.
Some rain sensing wipers require you to turn the wiper stalk to a certain setting. some require you to activate them with a button every time you start the car.
On older fiats for the "follow me home" lights you would turn the engine off then 'flash' the head lights though the headlights would not flash but a timer would come up on the dash to say how many seconds the lights would stay on for. That said I don't suspect this old method carries over to the Fullback, so again check the manuals.
Does it have the *original* Fiat Head Unit.
Replacing the original unit with an after market will remove the vehicle setup menus *unless* the additional required control unit(s) are installed as well.
