Technical Radio-cassete ad182
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
claudinho
galati
my radio-cass doesn't work as i expected!! the clock works perfect! i have the code but i can't put it in rad-cass because on the screen never appeared SAFE or any other message and if i press ON button the clock stops and doesn't work anymore till i set it up again!! does anyone have an advice for me pls??
What do you mean by set it up again? Which radio is it? Grundig what?
It sounds like the original radio is faulty. If safe doesn't appear then code should appear meaning its not protected and you should hear the sound from the speakers and the clock should be displayed. Have you checked the wiring? Tried it with the ignition on?
i tried everything that i knew but non of them worked! is a grundig ad182 h1! can you give another advice that you know? maybe will work hopefully!! thanx
i don't hear any sound even if the engine is ON!! i buyed a new pioneer cd player but i want to make the original radio work because the interior looks pretyer with it;) !!
The solder joints between the fascia and radio can become a dry solder joint. This stops the working normally. I would replace the radio with another Fiat Bravo/a, Marea Radio or buy an aftermarket one.
