Moggster
Good Evening All.
We have just Acquired a Dethleffs Globetrotter Premier A Class, and I'm doing some work on it as the Alternator Toasted its Self 100miles into the Journey Home.
While Im doing this , which is a pain to get at but not the worst Driveway Job I have done, I Thought I would do the Timing Belt & Tensioner & Pulleys as although recently done, the garage that carried out the work for the previous owners didn't do a good job and instead of removing the upper engine mount to remove the timing belt cover they forced it off and broke it into three pieces, lost one piece and split the main body of it for about 8 ".. So it all has to come off to do the cover anyway.
To top it off the drain pipe from under the cab internal heater matrix rubbed through on the cam pulley as the top corner they broke off , exposed the pulley..
So in light of that 'cobbled' job , I'm doing the timing belt etc again as they didn't replace the tensioner and I have no faith in any of the documented work they did.. Im also doing the Cam Seal, Cam cover Gasket, Water Pump, and AC idler while I have it all apart. Anyway I digress.
While underneath I have noticed that the aforementioned Radiator Support Crossmember is in slightly worse condition than the submerge bulk head of the Titanic... and so it is now off .
My question is does anyone have a part number for the cable clamp that secures the Starter Motor Feed Cable from the battery?? The Crossmember is easy to find but I can't find a mention for the longitudinal metal 'clamp' that bolts down on to the crossmember and secures the Cable ?
And so while I am asking about that and I take the support off , The A/C system seems to have not been a Factory suppled system , but an Eberspacher , at least this is what I have deduced from the sticker on the upper slam panel, and as such the Idler isn't standard and neither is the A/C Condenser , and I can't find part numbers for either of these to items, both of which need replacing!
Any Help with this would be greatly appreciated.
Regards Si
Regards Si
- Model
- Fiat Ducato 2.8jtd 8140.43s
- Year
- 2002
