stewie_uk
Hi all, thanks for time looking first of all - am new to this forum.
I've got an R reg Punto 60S, and am nicely clocking up the problems now. For the second time this year the head gasket has gone (done about 7k miles between March and now), and the garage I took it to charged £150 for fitting of a new gasket set, cam belt (as said it's been off twice now and needs replacing as is coming up to 54k miles on it), oil change etc.
Second time in a year, is becoming costly - I asked if it needed a skim but he said no. I asked if there was anything I can do to stop the problem. He said no. Now I'm not calling this mechanic a liar, but I've got the feeling he's taking advantage of me because I'm not mechanically minded.
So first question - can I do anything to stop the gasket going again?
Second question - all the hoses seem to be in the right place, but I'm getting no heat in the car at all since it was back (and for various reasons I can't contact the garage). Is it likely to be something like an air lock? I've tried loosening the reservoir cap after the car has been running and I get the usual expansion and air seeping out of reservoir, but that's it. Tried running engine with cap off, may have left it a little too long (overheat light came on), when light went off after I'd turned engine off and replaced cap, still no heat.
Third bit - have got a loose aerial on the roof, it's letting water in now and again, is original aerial but has some play in it left to right - any ideas how I can solve this one?
Last bit (cos am sure you're probably fed up with me by now!) do gearboxes go on these engines, as mine feels now and again that the clutch isn't properly down as can take a bit of a push to get into especially 2nd gear, when foot is firmly on floor?
Right, well thank you good people, I hope I can get some responses (anything is appreciated).
Stuart
Stuart
