Punto rear light cluster
M
Mark
Sorry! I know that this is a Bravo forum but everybody is so helpful here. My girlfriends Mk1 Ounto needs a new bulb in the rear light cluster. Does anybody know how to access the bulbs as it doesn't appear obvous to me.
Many thanks,
Mark.
PS I do have a Bravo!!!
punto
two 19mm fixings hold the lamp unit on, one is hidden behind a trim ,about half way up the pillar inside the car ,its round and comes out easily using a flat screwdriver to gently lever the edge up to reveal the fixing the other is in the lower section inside the luggage compartment facing into the lamp unit.Once they are removed the lamp unit will come out to allow you access to the screws that hold the two halfs together giving you access to the bulbs
Thanks. When you say 19mm fixings, are you referring to the large hex shaped bolt that is underneath the round trim cover?
lights
yes thats the ones ,be carefull not to drop one down the inside of the panel .....its a pain to get back out .
J
1
786
Dark Lurker
P
2
535
Joske
J
B
651
Brian
B
N
10
717
NickGr
N
