Hi Guys,
Can anyone shed some light on an emissions problem i am having with a N reg 75 SX model. Failed big time on emissions. Smells like its over fueling There is a pipe disconnected from the back of the inlet manifold which goes upto the blue unit with 3 pin plug (bolted to the bulkhead) When i connect this pipe it starts running rough and when you rev out a little, the engine cuts out. Is this anything to do with the co2 ? and what other parts should i start checking. I did replace the 3 pin unit, but it made no difference. All help \ suggestions will be gratefully received.
