J Jamesclegg1994 New member Joined Jan 7, 2015 Messages 24 Points 4 Jan 7, 2015 #1 I bought a new head unit for the car I am having great difficulty wiring the new harness I'm pretty clueless atm Last edited: Jan 7, 2015
Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,382 Jan 7, 2015 #2 Jamesclegg1994 said: I bought a new head unit for the car I am having great difficulty wiring the new harness I'm pretty clueless atm Click to expand... Give us some more information You've got the stereo in - but it dont work? You've got a different set of connections? Cant get the radio antenna to fit? Whats the wiring harness you got? Any chance of pictures - take plenty and upload It will help us lots when we can see what you got / not got Ziggy
OP OP J Jamesclegg1994 New member Joined Jan 7, 2015 Messages 24 Points 4 Jan 7, 2015 #3 I have it half sorted I have gave up the now you hear the CD spin up but it's like there isn't enough powering for it to turn on properly
OP OP J Jamesclegg1994 New member Joined Jan 7, 2015 Messages 24 Points 4 Jan 7, 2015 #4 I tested the unit on another car to check if the unit was faulty but spun up and started fine I think it may be something wrong with the car rather than the adapter cables
Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,382 Jan 7, 2015 #5 Jamesclegg1994 said: I have it half sorted I have gave up the now you hear the CD spin up but it's like there isn't enough powering for it to turn on properly Click to expand... Right - your probably a can-bus'd radio Is yours a late 2003 mk2? As the later mk2's became can-bus radio's before the mk2b kicked in The car tells the stereo to turn on - via the data lines in the stereo Where as early mk2's were the traditional 12v switched feed You will probably need to add the switched 12v feed into the stereo from the cigarette socket Ziggy
OP OP J Jamesclegg1994 New member Joined Jan 7, 2015 Messages 24 Points 4 Jan 7, 2015 #6 It's early 2005 mk2 54 plate
HGTTRACKCAR Patron member Parked in the garage Joined Oct 27, 2011 Messages 26 Points 9 Jan 8, 2015 #7 I presume your fitting an aftermarket CD player? if so do a search on here loads of info, but you need to sort the ignition live and constant 12v
OP OP J Jamesclegg1994 New member Joined Jan 7, 2015 Messages 24 Points 4 Jan 8, 2015 #8 Yeah I have the adapter with the long red cable and a short yellow one but it's after that I don't know what to do with they 2
OP OP J Jamesclegg1994 New member Joined Jan 7, 2015 Messages 24 Points 4 Jan 8, 2015 #9 Ziggy122 said: Right - your probably a can-bus'd radio Is yours a late 2003 mk2? As the later mk2's became can-bus radio's before the mk2b kicked in The car tells the stereo to turn on - via the data lines in the stereo Where as early mk2's were the traditional 12v switched feed You will probably need to add the switched 12v feed into the stereo from the cigarette socket Ziggy Click to expand... Hello do you know what to do with the long red cable and short yellow one?
