General Punto Mk 1 Ignition System Replacement
JMJR
Hi all
I am writing to check some information. I had aborrowed Punto 60 Sx 1999 from a friend and some scroat tried to steal it. Now have damaged ignition, ie the ignition key unit is smashed. The cost of professional repair is uneconomic so to reimburse friend I am considering buying the car outright and fixing it up for myself.
So if all goes well I'll be a Fiat owner again!! Have driven a 126 in the far past and loved that one.
I was hoping that someone here might have answers to some basic questions
So as far as I can gather I need a new ECU/Code box/Ignition Lock & key. which I can get from a local scrap yard.
Would that be all thats likely to be needed?
Edit Doh!
This is the guide for me. So only the question about the steering column remaining
https://www.fiatforum.com/punto-guides/219588-mk1-punto-replace-ecu-code-box.html
If the steering column (from the universal joint to the steering wheel) is damaged is that a scrapyard replacement ( I am wondering if there is potential engine management unit issues) or is that on later Mks.
Cheers,
John
Hi again.
Thanks for the help.
I fitted the glass today and also got the starting working.
I have managed a fix- I just fitted a replacement ignition and have the old key taped to the sensor ring [all stowed away in the fuse box area.]
Ignition replacement was straightforward but two things remain that are puzzling me.
First is there was a lead and plug damaged during the attempted theft. I rejoined the wires but cannot locate a socked for the plug- Is this an unused (in this model) plug? Wire colours are 1 Violet/Black and the other 2 Grey. Plug is white. Pics attached.
Secondly What is the donut shaped device behind the steering wheel? Pic attached- There is a yellow sticker on it that looks as if it is a service warning? Was there any particular thing that needed doing here? I just refitted it as it came out, as best I could.
Thanks,
John
attachment.php
attachment.php
attachment.php
