Punto 1.3 MJTD Engine Check Light P0106
Cyril64
Hi All
I purchased a punto 1.3MJTD approx 6months agon, but during a journey last week the engine check light came on, the car appears to drive fine with no loss of power. I have checked the wastegate by removing the turbo and it appears fine, also removed the MAF and reconnected but a second code came up on disconnection also the MAP sensor disconnected with another code. could anyone help on suggesting the most possible solution as i am now running out of ideas through the various leads from this excellent site.
Thanks in advance
The only fault I've had on my Panda MJ was the MAF sensor which was replaced and cured the fault
