Technical Problems with my DPF pressure sensor?
bunterboy
Qubo 1.3JTD 2011 My engine management amber warning has been on for several thousand miles. The DTC fault code is P2453. I can clear it but it comes back within a few miles.
Car seems to run OK, although fuel economy is slightly lower than normal. (An 'Italian tune up' when I was in Spain in the summer cleared the problem for a few days.)
I changed the DPF differential pressure sensor but it made no difference.
Not got the dosh for the Fiat dealer at the mo.
Anyone got a suggestion as to what I might try?
Any advice welcome. Ciao Bunterboy
Model
Qubo 1.3JTD
Year
2011
Mileage
98000
It's probably the dpf , clue being Italian tune up helped before.
Dpf cleaner could be worth a try
Thanks Jackwhoo I did wonder about that, not checked all the pipework properly yet either. Need to get it sorted before MOT in March.
I just spotted one of the pipes feeding the sensor has a hole in it, might be the cause. Let's hope so!
So today on closer inspection one rubber hose has a a hole burnt in it the thinner one has some heat damage too, both are around 10cm long. I managed to change both and replace the original sensor. I cleared the fault codes and so far the warning light has not come back on. My only worry is I used braided fuel pipe, perhaps it should have been silicone. Might not last long.
Just to report the fuel hose repair seems to be OK at the mo. I'll report back if anything chamges.
