Technical Problems with electric
Drag
When I try to switch the lights my motor is turned off. Also I can´t turn on an emergency lights. I just hear a noice in my fuse box, and the heat temperature needle goes on maximum. Other commands on my sticks are OK.
Do you mean when the engine is switched off you can't switch on your lights? Do you mean you side lights and dipped beams or your interior lamps?
What is an emergency light?
What type of noise are you hearing from the fuse box, a clicking/switching kind of sound?
When I turn the lights on my engine turned off. I mean the outer lights.
Yes, the sound is clicking.
Maybe your Fuse box has condensation or water in it.
This is what I did when I had an electrical problem:
Disconnect the battery and Remove all the fuses and relays from the fuse box.
Check all fuses are ok.
Do not know how to check a relay but tapping them softly sometimes fixes them.
Leave them to dry overnight in a warm place (Not Hot).
Plug them all back in in the morning and reconnect the battery.
If you still have a problem remove all fuses and relays again and put them in one by one.
After each one you put in try to start the car and check to see if there is still a problem, hopefully you can isolate what circuit has the problem on and refer to the owners manual.
