Problems engaging gears (intimitant)
C
Christorg
Whats the most likely problem do you think..
Clutch seems fine most of the time, but on occasions (lately) i just cant find a gear whatsover. Have to pull over to the side of the road and then try and engage a gear, by this time i can find all the gears again asif there isnt a problem at all!!! Very intimitant. Clutch feels fine otherwise.. no slipping or anything. Although lately has winned a little when enganging a gear while downchanging.
Any advise would be great... Cheers.. Chris
howdy bud,
firstly get some gear oil in the box, it might need some.then look at the gear linkage.
check all the bars and make sure they are not bent,or any off the ball/sockets are not worn.
also check near the slave cylinder for any sign off leaks, its just under the battery tray..
hope this helps
big al
I
2
1K
Dark Lurker
P
2
627
Justin
J
W
916
wakka
W
C
485
craig
C
