Technical  problematic tyre pressure sensors
Leeg1987
Good morning everyone
I've had the issue for the past month. The message lhs and rhs front tyre pressure low flashing at me checked tyre pressures and both are at correct pressure I've even put a little extra too see if that knocks it off with no luck.
Now I'm starting to think sensors are faulty,I've read a post on here of a different model having wheels replaced and tps light staying off will this work on bravo if so I will get valves changed.if light stays on can a auto electrician are fiat disable tps.
Thanks lee
Just been on to fiat ifs added extra but they can't turn it off and they want £100 just to diagnose fault. :(
Also if I replace valves the light will just stay on. Not good
Had this with. Mine in cold weather but a bit extra pressure always worked give me. The sensors have a limited life span as I believe they have a sealed in battery if your car is an early example it could just be that, after market replacements are starting to appear but I don't know if they are done for fiats yet. I would suggest getting a copy of multiecuscan scan assuming you will keep the car for a while it will pay for itself when dealers charge silly money just to plug the diags in. If you are not confident of it yourself you could then always nip your laptop and car round to a more friendly trusted independent garage for them to have a look no need to stick with main dealers
