Got a tough one...
I connected the ECU scan (great tool!) and get an fault message, reading:
Problem on the actuator control lines, a short circuit could be present to the ground or to the actuator
Check:
-continuity and insulation of the conductors from the actuator to the ECU, and mainly:
pin 1 actuator connector -- pin 111 ECU
pin 2 actuator connector -- pin 109 ECU
-actuator resistive value (reference 10 Ohm approx.) and insulation to the ground
Moreover, check the presence of the actuator control signal (square wave) on its pin 2, engine running and by means of an oscilloscope
The reason for this fault is Open circuit / Short circuit at +V batt
The current status of the fault is
The error counter value is 48
Where is this actuator located? What does it do?
Any ideas how to fix this?
Check:
