Hi all,
I have an Abarth 500 but posting here for visibility plus the issue isn’t isolated to the Abarth, but rather applicable to all 500s.
Basically my power window won’t roll back up after opening. I know there are two relays on the body computer PCB in the driver footwell where one is responsible for the down movement and the other for up. I can hear a clearly audible click on the down relay, but only a very faint click when pressing the up button.
What I know:
- passenger side works fine and clicks as should
- switched the buttons around to eliminate faulty button possibility
- motor is fine (I closed the window via direct 12v)
- removed body computer to physically inspect the relay - saw no cold solder, gave it a little nudge as well
- attempting to close the window directly via MES doesn’t work
- the issue occurred after I drove the car with a faulty alternator (the regulator failed while driving) and I had this window open
- it didn’t occur immediately, but approximately the next day (opened the window and it wouldn’t go back up)
Anyone ever come across such issue before? Any insight would be greatly appreciated
What I know:
- Model
- Abarth 500
- Year
- 2015
