General Plug/socket identification.
Autoboxer
Devon
I recently replaced my 244 Ducato camper with a 2015 X290 Ducato Globecar a bit disappointed to find Fiat still hadn't sorted the water leaking from the screen onto the engine but all sorted now with mastic and clearing afew blocked pipes. During the process I found a connector which was very wet it's clipped to the fuse box next to the air filer I couldn't get it apart so gave it a good spray with suitable oil. It would be nice to know what system it's for in case I get issues in the future. It looks like a ten way connector with seven being used 3 green 2 brown and 2 white (some with tracers).
Help with id much appreciated.
Hello,
This part stresses me a bit...
I think it would be easier to identify if you take a photo with connector plugged in the original location. With a little bit wider angle.
Hi thanks for having a look, I've attached a wide angle picture with the headlight removed in doing so found a sticker which has identified it as a connector for the heater controls also it's actually a 12 way connector not 10 my mistake (can't count) So thanks to your reply I've now identified it.
