Please help
Please help
Kris0b92
Why does my fiat punto mk 2 have squeaky sUspension when I drive my car
Because the squirrel you ran over is trapped in the mudguard!...No seriously though, could be any number of things but a leaking shock absorber will squeak and fail MOT. Simple shock test, push down on the car on each corner, it should rise back instantly, if not, have a look at the shock for signs of oil coming out of it and check the springs bushes and placement in case they've moved. Rusty springs will also creak. If you find a leaky shock or knackered spring, change both sides as you would brakes to keep balance in the car. Can throw tracking out if really bad too so watch tyres for wear on the edges.
Ive had alook and the push test an the shocks are fine so think it will be the springs how much do they cost to replace
Vary greatly depending on where you go and the quality of the spring. Last ones I had done on the front (replace both) were £58 each fitted. Sadly the car was written off 3 days later by some stupid arse skipping a stop line!
