Please help!!!
Please help!!!
rock n rolla
my doblo cargo went gutless all of a sudden. no fault code? no problem starting or running, just seems as there is no boost?
took the turbo off and the specialist i took it to says its fine, the actuator was sticking slightly, but the turbo seems fine.
re fitted the turbo yesterday and still the same??? cant see any leeks or split pipes or wires off anywhere. it seems worse from cold, then gets a little better when warmed up???
any help would be muchly appreciated. dont fancy an expensive trip to the main dealers:(:(:(
Possibly a different engine, or even a different problem, but my Panda MJ (1.3) has, on a couple of occasions lost power. The incidents have been very specific, namely changing down from 5th to 4th at about 50mph and suffered a sudden, very short drop off in power, it almost felt like a petrol engine with a loose HT lead. It accelerated back up to 70 OK but during the remaining 9 miles or so of the Motorway journey seemed to be totally lacking in acceleration.
Back in a 30 limit it seemed a little sluggish. The orange/yellow engine warning light came on. It was still on the next day although after I switched the ignition on and off 4 or 5 times it went out. Apart from these 2 incidents the acceleration is alright.
I realise this doesn't give you an answer to your question but if it's a similar fault then maybe there's a common cure.
