Technical  Pistons Question
Corby, Northants
Hello again,
Still waiting for some money to come so i can update the turbo thread! I do have a question to ask though, the pistons from a 1242 8v SPI engine, could i remove them from the engine and put them on a CNC lathe to skim the required amount off of the top of them for HB? or would i be removing some kind of hardness coating? I thought i better ask the question before i go off on one trying to find information and working out CRs etc.
Many thanks in advance
Lenny
PS - Mods move as applicable didn't know where to put this one. :eek:
Hello again,
Lenny
I use the 1242cc 16v pistons in my 1242cc 8v turbo and this has shown to be a good sollution.
If you mashine the original pistons make sure you dont mashine down the piston crown so the pistons get a flat top.
don't use VA as an example, they machined them flat i think. check for pics of emmas hiboost using mahle pistons.
It also stresses the ring lands more - best bet is go for a set designed for a turbo engine with larger and deeper lands. But machining will do if you can't afford those.
I agree with that comment re vAD's kit. Theres something about the vAD turbo kit I just dont like. The fuel controller is bodged for the LB, the lack of an ACOC worries me from standard....it just seems like a parts-bin special.
The Novitec conversion is much cleaner, although much more expensive!
According to my calcs, a 2mm reduction in profile is required (assuming the piston crown profile is duplicated 2mm nearer the gudgeon pin)
Ceramic coating could be expensive but may be a winner, as it should help heat disspiation a bit.
thanks arse :)
Whats this i've been reading about the standard pistons don't have enough meat on them to machine them down? also when you say replicate the crown 2 mm down, would i also need to replicate the valve cut outs on the top face of the piston? or just the outer raised crown?
Many thanks again
Lenny
thanks arse :)
Everything on top face.
Ive heard that too....but I dont know what constitutes enough meat TBH. Id be interested to run a thermal / stress analysis on a piston if I had the time , inclination and understanding! But I dont really....:(
am in talks with a guy about getting forged internals made up for mine at the moment could have a word for you if you want to chuck some money lenny :p
