I've been struggling with the idle of my 1991 Uno 1.1 ies. Once the engine temps hit about 70-80 on the gauge, the problems appear. At idle the engine starts surging at a pace of once every 2 seconds. RPMs decrease and possible misfire occurs (this can't be seen clearly in the cylinder burn time measurement I made). Also sometimes when dropping to idle from revs, the revs go very low and might stall. Runs great otherwise.
I have tested/changed almost everything: plugs, plug wires, wiring, grounds, distributor cap and rotor, igniter module, vacuum advance, vacuum hoses, carbon canister valve, head gasget, injector, throttle body, fuel lines, fuel pump, fuel filter... Ecu has been reset each time.
Also, after starting the alternator lamp is always lit until I rev the engine a little. This is non-dependant on engine temp. When starting with engine hot, surges are very light until alternator starts charging (engine revved a bit). I haven't tested a new alternator, but have changed the regulator.
Closest I got to solving it was when I changed the throttle body, it ran great for half an hour. I tried adjusting the TPS, with no improvement. Electrical parts have been tested with a multimeter and oscilloscope. Oxygen sensor values loop:
RICH-LEAN-RICH-LEAN-LEAN(surge)RICH-LEAN-RICH-LEAN-LEAN(surge)....
Cause or symptom?
The surging gets worse in cold weather, when I changed the throttle body and noticed improvement I did it in a warm garage.
Any ideas?
Cause or symptom?
Any ideas?
