I think you'll find that increasing boost does not increase air flow as you yourself have the stated the reason for this. You have quoted boost in BAR, BAR is the AIR PRESSURE this has nothing to do with air flow which is measured in cfl (I think), which are 2 very different things, therefore the ECU has to be reprogrammed to accommodate the increase (OK on the UNO it can go to 1BAR without reprogramming), otherwise you get fuel starvation & possible detonation which can lead to at worst pistons melting. This is why you can run a bigger turbo with less boost but get the same results as it is flowing more air due to having bigger impellers. Any tuner who knows their onions will not fit one, it was a popular mod on turbo cars in the 80's early 90's when there wasn't the depth of knowledge that there is today, & this is why turbo cars got such a bad name for reliability, I'm not saying that bleed valves are all bad ,all I'm saying is they're crude, they lower the lifespan of the turbo's & head gaskets etc if not used properly i.e. turned up to indefinable levels & there are better more reliable ways of getting higher boost levels
You see a turbo does not produce more boost when you fit a bleed valve etc, it still spins at the same speed as before flowingh the same amount of air, because it runs off the exhaust gases, all you are doing is increasing the pressure in the system that is normally controlled through use of the waste gate letting excess pressure out. You wouldn't want your waste gate open as you would then get no boost, thats why you fit an uprated wastegate because when you up the boost, you can get whet is know as wastegate flutter, which is when its opening a closing ever so slightly but rapidly as it doesn't have the pressure in the spring to hold the boost in. On the integrale the waste gate is computer controlled rather than spring controlled, which means it opens & closes to produce diff boost levels dependent on gear selected, 1st 2nd gear 0.6, 3rd 0.9 4th 5th 1.1BAR but thats a smart system that would be expensive to replicate in a car without it.
Aaron.
