My car has gone into limp mode. Diagnostics says low particulate fluid and blocked particulate filter. Can someone help with these questions:
1. Where is the fluid tank?
2. How much does it hold. If system says low fluid, does that mean it needs completely refilling. The fluid comes in 1 litres (£33) or 4.5 litres (£130). So, will I need the full 4.5 litres?
3. Do I need a refilling kit as well?
4. After filling, can the particulate filter be regenerated, or will that need replacing as well?
FYI Diagnostics showed:
P1429 Particle Filter Pressure Difference signal
P1447 Particle Filer
p1435 Diesel Additive System
