Technical  Part Numbers??
Fiat500x2304
Help!!!
I'm trying to find a part number for the correct lambda sensor but I cannot find any breakdown drawings, can anyone direct me to any?
Specifically, I'm after the lambda sensor part numbers (pre and post Cat converter) for a 2016 500X 2.0 Diesel 4x4 manual.
I have an issue and have managed to get down to it being the post cat lambda sensor - but for the life of me I cannot find the OEM part number.
Well I could suggest but it would be a small risk.
I can do part numbers to 2014 but would need more info on your exact engine. Type number, actual cc, I assume 16V, etc.
Fiat tend to be reasonably consistent with parts usage over their standard engine ranges so it is possibly likely that the same pre & post lambda sensors are used.
With 2015 Fiat vehicles then ePER etc. will be of no/little use. Fiat moved to online systems and KeyEPER which is now a dead duck. You can look at other recommended part sites but generally they are pre 2015.
To get an exact part reference lookup then you need to use your local Fiat parts dealer or find someone who has paid (expensive) access to Fiat's parts system.
Help!!!
Pre Cat : 55275929
Post Cat : 55273732
