Technical Parking sensors
Many kits have a small piezoelectric buzzer that beeps. They are plenty loud enough! I can hear mine located behind the boot carpet, with a boot full of stuff and car load of people quite easily
Just checking some out my bravo is white do they all come black and you paint them yourself?
Also with drilling what's the best way obviously being very cautious if I do go ahead? I am only considering these as I hit a small dwarf steel post which was out of my vision in my old bravo
I went for the first set of £14 ones on ebay. Chose the closest colour to my car. They're close enough for now. I have a few scratches to sort, so might just colour match the sensors too.
As for drilling, I was fitting a replacement bumper anyway, so I could see (and use) the existing marks to drill through (Ford* very kindly marked up the bumper for sensor holes on all of their Focus range - well, certainly the mk2.5) with it off the car.
If you're doing it with the bumper on the car, I'd suggest using a strip of masking tape across the full width at the height you want the sensors. It's easier to mark on...and if you can get rough measurements from a factory fit OEM setup, you can make it look almost stock
You will get a hole cutter with the kit, but a small pilot hole is a good idea. And run the blade of a sharp knife around the inside of the hole before pushing the sensors in.
(*Yes, I know that a Ford Focus isn't the same as a Fiat Bravo, but the premise is the same...holes in bumper, wires into car, tap reverse light for power and hey presto)
