Re: 1498cc engine in 1108cc Uno
if you want some real fun a good swap for a 1303cc strada derived uno is the 1500 strada cam shaft advanced 9 degrese or their abouts and timed to mach
rev it to 8500 fit a biger eahaust and fiat croma carb and richen it up then you got about 100 bhp
Sorry to hijack your thread totnesmonster (by the way, I changed the cam in my Uno 60 (1116cc, 58bhp) once, I put in the cam from my FIAT 128 1290cc Coupe, all clearances were the same but there was a lovely roar from the engine and definitely an extra 5bhp or maybe more
The 128 Coupe 1116 had 65bhp claimed for it and that had the same camshaft but lower compression. However I found my Uno used more fuel and there was a bit less torque (swings and roundabouts) so I eventually put the original cam back in. But - and here's the rub - when I fitted twin carbs to my 128, it had MORE torque and the same or better economy, so if I'd put better carburetion on the Uno I reckon I could have reaped great rewards...)
...but anyway, how fortunate that my friend James (jjhepburn further up in this thread) has just fitted a 1498cc engine into his Uno (originally a 45), the engine being from an X1/9 but previously installed in an Uno so came with an Uno 70 gearbox of the bottom-change type (like an early Turbo but with Tripode driveshafts). An Uno 70 has provided a number of useful parts - just the exhaust remains to be made now. We changed the cambelt and noticed the timing had been one tooth off. Is that likely to have been 'correct'? Or do we need a vernier pulley to get the 9 degrees?
I'm not sure if my timing light goes up to 'mach', or indeed whether timing is usually set to the speed-of-sound
We definitely need a bigger carb as it has a poxy Uno 1301cc carb (Weber DMTE 30/32) at the moment. Those things are bad enough in an Uno 70 without expecting more power out of them... I tried connecting the accelerator pump electrical-doodad last night and couldn't for the life of me see what effect it was having - I operated the throttle and fuel pumped out whether it was 'on' or 'off'.
I was wondering about a Lancia Beta carb (the older parts are easier for us to get than the newer parts, not many dead Cromas around as the blasted things don't rust as well as the older FIATs...)
-Alex
