Good morning all.
Does anyone know if fiat made a 4x4 auto. It would be good to try and get one.
Mat
Hello.
I've never seen one either just wondered.
The selecta box isn't that strong so maybe not maybe not a good idea with a 4x4.
I'd prefer to keep them standard so probably wouldn't alter it.
Thanks for your help.
I'll have a look for a standard one.
Mat
And the other thing to factor in would be how would the offroad capabilites be affected by it being an automatic? The reason I like manual is because I feel like I can have more control over the car, switch to lower or higher gears where needed rather than the automatic box deciding that. Factor in that when you are offroading you will need this control even more, I would think that putting an automatic box in a panda 4 x 4 would not be a good idea in terms of offroading.
But I could of course be completely wrong given my lack of experience with automatic cars, and that I dont have a 4 x 4 panda, I me be making assumptions that are completely wrong.
My Isuzu was an auto: normally just driving the rear wheels... -- but with a low-ratio and high-ratio 4x4 gearbox. Best 4x4 I've ever driven. Would go anywhere....![]()
Does a Selecta have ratios?
I'm not actually being silly - if it's continuously variable are there ratios still? It has normal drive and low (which makes more noise for no apparent reason/result in the Uno).
I dont know
I should never have waded in on this topic should I![]()
I wouldn't worry, I have no idea either......![]()
Automatics in general are generally said to be better off road, mainly because you have two pedals - less to think about when you are half way up a 45 degree hill or about to tip over on cross-camber. But I have driven both formats quite alot and I am happy with the manual![]()
