General  Panda (2005)
barbar2013
On the brake master cylinder, my Panda (2005) has 4 hydraulic connecting pipes. Two of the pipes are connected directly to the master cylinder as usual, while the other 2 pipes has a 50mm adaptor which is fitted to the master cylinder and then the 2 pipes are connected to this adaptor.
Can anyone tell me the use of this adaptor. I'm assuming its some kind of valve.
Most likely to be pressure reducing valves on the pipes connecting to the rear wheel brakes to improve vehicle stability under heavy braking.
there a few different systems
with ABS and without
with ESP and without
With robotized gearbox and without
are all different, there might be more ?
I would guess yours is without ABS and they are the rear proportioning valves
however without some photos and more information its a wild guess.
http://4cardata.info/elearn/169/2/2009000/2000901/2001394/2752736
My Panda has no ABS. Now I'm quite sure they are valves. One of them is leaking oil. I assume it cannot be repaired. Can these valves be bought easily from a spare part shop. What is the technical word of these valves.
These are well hidden in the Fiat parts listings, but appear to come as a pair, under the Fiat part number 77362727.
If you have a Fiat dealer, you may be able to order a kit from them.
Be careful when searching the net. I did a quick search, and there are many listings showing a picture of a rear mounted pressure proportioning valve, which is not what you want. So beware of listings with no picture.
Found a Bosch cross-reference, seems to be Bosch 0 204 131 714, but again, be careful as there are listings without pics, and again some of a rear valve. It appears that aftermarket cross-referencing has made a mess of this, and is perpetuated across many suppliers.
Found this listing: https://www.ebay.co.uk/p/1909497925?iid=324463152585
Expensive little things, although that should be for the two.
comes under several names
such as
rear brake proportioning valve
rear brake bias valve
rear brake compensating valve
Rare here in the UK where even when it was an option on the early actives most people opted to upgrade to ABS
Probably easier to find in other countries ?
i tried to buy 2 of these Brake power regulators for my Panda, but I could not find. I went to a scrapyard and I found 2 fitted on a Fiat Punto. From the outside the are similar to those of the Panda. They look in good condition.
What I would like to know maybe someone knows if the are compatible to the Panda.
unfortunately PV430 bosch brake power regulator only seems to be for the Panda
