General  Panda 1.1 Selecta 1996
pechmo
Hungary.
I am about to buy this Panda for about 900 Euros in Hungary.
Is it worth buying, knowing that it had some demage to the sides (know looks fine) and ran 80.000km. The only thing I am uncertain about is the Selecta gearbox. Does anyone faced any serious problems with a similar car?
Thanx.
Attila
Not personally, but.. if you search you will find others having problems with the selecta gearbox.
As I understand it is very expensive to sort out if you have problems - commonly total replacement, which will exceed the value of the car.
Take care.
John H
Pechmo,
I have had a few problems with the selecta gearbox, but admittedly I have done nearly 200,000km on the engine.
The trick is to keep on top of any problems. (true for everything with a Panda)
Let me know if you need any more info
Andy
Hi Andy,
Thanks for the reply on my topic.
Could you please share as much of your experience as possible with me regarding your Fiat Panda, especially about the gearbox itself.
As I mentioned I am about to buy the car; it will be used by my five for relatively short distances.
I think buying the car would be a bargain. The only thing I am afraid of is the automatic gearbox. Although I have not found any complaints, or negative opinions about it yet.
Thanks in advance,
Attila Molnár
Attila
Pechmo,
I used to do an average of around 150 km per day and
the only real grief I had with the gearbox was having to replace the clutch brushes on the transmission once. I have had some problems recently, but this is down to the fact that the car has been off the road for a long while now.
The clutch itself is pretty good, but John H is right when he says that problems are expensive to fix when the gearbox screws up.
Check that the gear lever clicks into place when the you select drive, reverse etc.
The light indicating the gear you are in should only light up one of the indicators, if it starts to flick back and forwards(assuming the gearstick is sitting correctly), then you may have a problem with the gear selector cable. (easy to replace, and rarely gives trouble)
The ECU (electronic control unit) rarely screws up ,and I have had no problem with mine
I settled into the habit of checking the gearbox oil every three months, and have only topped it up it twice.
One problem with the Selecta Panda's is that the front brakes are not standard Panda fittings. They are pretty expensive to replace the calipers. I have another two cars which I keep on the road and the Panda fell into neglect. Hence the reason for replacing the calipers, and discs.
Make sure that you run the car on long journeys as much as possible. I drove from my house to Edinburgh on a motorway every working day, and the engine is still running sweetly.
The Haynes manual 0793 covers the selecta models for the Panda up to 1995, so I would recommend it as a useful tool.
let me know if you need any more info
Andy
Hi Andy,
Thanx for the info, it should be enough to help me with my decision.
Attila
Attila
Be careful with Haynes - they used the same manual number for all (4?) different versions:(
The version which covers to '95 has a green cover, rather than blue. Earlier (to 93 version - maybe others too) cover the CVT box in a bit of detail: microswitch adjustments etc.
Take care.
John H
Well spotted John,
The ISBN number is ISBN 1 85960 143 X
John is right - the cover is green and it has a section devoted to the Selecta model.
let me know if you decide to buy it - that way I know at least one other person who owns one!
Andy
