Technical Palio clutch problem
Hi Guys,
I felt my clutch pressure on the pedal was getting lower,gears getting sticky and the car cannot go into reverse while switched on,it grinds.
I checked the slave cylinder n the gearbox and it was leaking.
I replaced it now with a reconditioned one,but the problem is still there,sticky gears,grinds into reverse when car is switched on.
I bled the system twice to make sure all air is out.
Any suggestions?
The cars clutch is slipping,suspect a worn clutch plate.Could this add to the problem I am having on the hydrolic system?
thanks
Chris
