Technical  Output Converter To RCA (helppppp)
benbrook1
essex (southend)
where do i put the Output Converter To RCA to the fiat grande punto 06 headunit >?????
looked at the guide but stil dont understand
Ground wire to ground (clean chassis bolt or nut)
then left hand (front or rear) speaker outputs for L channel and right hand speaker outputs for the right
I put mine in the boot when i did the rear speakers and took the supplies from the back speakers... but you can to in at the Headunit
how do i run it to the boot do i have to run a lead for each one from the head unit ?
so 5 leads from the head unit to the boot ?
andy... make me look so dumb haha why did i not think that
the only thing I'm not to sure how to and where to attach it to the head...
pop the hu out
look at the plugs
https://www.fiatforum.com/attachment.php?attachmentid=76744&d=1271695342
the plug that is marked speaker (that label is next to the plugs)
is the one you want to tap into ideally you would want to solder and tape them up if not use crimps or terminal block.... (never a fan of terminal block personally)
you will see on your line adaptor there are 5 wires...... they should be marked
and just match them up to the correct speaker output wires
(ignore the earth right left label inserted on the above pic)
And when you pull your Live feed wire in for your sub do it Properly and fuse as close to the battery as you can (big cause of car fires is bad wiring especially high power carrying amp cables)
