Technical  One touch window on passenger side?
eggy43
West Sussex
I've a '68 plate 2.3 Ducato L2H2.
From the drivers side switches: One touch window up and down works on the drivers side window, but only down on the passenger side window.......
Is this right? (Seems a bit odd to have it that way)
I've tried holding the button in the close position for a few seconds after closing the window but that's not made any difference.........
There is no one touch passenger side window up from drivers switches
It is to stop the driver mistakenly harming any passengers arm/s other bits sticking out open window
The driver has to actively hold the up switch to harm passenger
Just for reference/ anyone else
'One touch up' doesn't work on the passenger side at all.
(I did wonder if it was just disabled from the drivers side so had to go and try it!!!) :ROFLMAO:
Have you tried to “teach it” to one touch? i.e hold the switch for ‘down’ until it hits the bottom but keep the switch pressed for a few seconds then do the same for ‘up’ or if you have a diagnostic tool some have window re-learn function.
I've tried holding the switch but that hasn't made any difference.........
I do have MultiECU so might have a fiddle with that. :cool:
It’s controlled by the module, early versions were separate, later incorporated into switch units. There are also some anomalies across the Fiat range, my cross has one touch windows drivers and passengers for down, the daughters has it only on drivers side, they are separated by just a few months in build date so suspect it’s a case of ‘whatever came out of the parts bin’
