do you need to use fiats own gasket when puting the a new sump on , or will any type of instant gasket work. my sump has had a small leak for a couple of months now, but thanks to to the local council and a new speed bump it is no more.
there is no gasket, you have to use a loctite gasket sealant, leaking sumps are a common problem with cinqs, i had a new seal put on mine recently, there are how to threads if you do a search,
