Technical Oil leaks 244Z 2.8 JTD September 2002
Atmo
Hi everybody,
just purchased the model above, replaced all wishbone bushings, cambelt and so on.
Very happy with the van but canT find a slight oil leak.
Does not drip when hot or running, only cooling down over night it stains a dollar coin sized spot.
Also had a diesel leak at cold start which disappeared after fiddling around with the quick connectors on the pump.
Oil leak seems to come somehow from behind the pressure pump.
Anybody got some ideas or had the same problem?:worship:
P.s.: There is absolutely no way to find a Van/engine manual anywhere on the net. The Forum downloads don't work at all. So, if anybody got some, please attach as PDF, so we can all have it.
Cheers,
Atmo
Cheers,
Atmo
Cheers,
Atmo
The downloads work you're doing it wrong.
The fiat manual is a cd based manual you won't get a pdf version.
You need windows computer or a windows virtual machine to run it.
https://www.fiatforum.com/downloads.php?do=download&downloadid=439
a) Download all the parts from link above
b) Extract the file from downloaded parts with winrar / 7zip etc.
c) Burn the extracted file to a cd or mount the cd as a virtual cd drive
d) Run setup on the cd to install
e) Run eLearn to start the manual
thanx a lot. I might have managed to download the files with my Mac.
So now I have to find a windows computer plus a windows programming wiz to find and download all the windows gear to make it happen.
Ups, need to get a cd burner as well....
That E-learn is a separate programming on top of the cd which is to be developed/burned? does it need to be somehow programmed into the files of that cd or is that just a separate program to be able to read the files on the cD?
I tried to burn it but no success. My Windows skills stop with XP where you still can access dos to get things done. For seven I guess I need to get some advanced training first...
Up to now I put about 30 hours of work into it with one LinuX/Xp Laptop and my Mac.
Not the slightest chance so far to go anywhere.
It would be great if somebody could upload the whole story as a Torrent, so people without an It degree can access the data.
Hey,
still, thanx a lot for your effort and help!
Cheers,
Atmo:worship::idea::bang:
