unoracer
I am currently looking at fitting an oil cooler to my normally aspirated race uno, which has the strada/x1/9 1500cc sohc fitted. I intend to use one from the uno turbo mk 1, along with the sandwich plate/pipes etc again, all from a mk 1 uno turbo. As I am not a mechanic, I am unsure whether there will be any problems using this. I am assuming it will phiscally fit/connect up as the engine blocks are almost the same (bar longer stroke on my engine) Can anyone advise on anything I need to do ( I have heard that the cooler should be at least level with sump etc?) Any help/advice would be appreciated!
