Full engine rebuild after cambelt went. Now won't spark. Checked all wiring n plugs crank sensor still no joy any ideas. Also had it on computer showing no codes
Yea taken all coils with plugs in n turned it over no spark attall few people think the imobiliser has kicked in. All dash lights work also fuel pump. Possible ecu not. Sure
Changed crank sensor checked all junction boxes. The dash lights are showing asr failure n esp failure which dnt have owt t do wi spark. Also engine managment light is on n there's a car with a paddlock threw it showing which I'm now thinking defo imobiliser. I've found a code card with electronic code n mechanical codes on it. Prob is don't know how to use it
paddlock is imobiliser problem if you have 5 digit electronic code you can see if your car is able to do emergency start procedure in link below post number 7.
Battery is ok running 2 batterys swapping with other car. Tryed the code on pedal buisiness no joy hammer out time lol. Might have to call sum1 out. Car is project ran out off tax mot has been tickin down for 5 months the mot. Due july. So need this running as know it will be a crackin car all boiling down to this imobiliser now I think
