crossy1113
- Joined
- May 25, 2013
- Messages
- 3
- Points
- 1
I have two problems with my little 94 Punto
1st one is, sometimes not all the time, something around by my break fluid makes a knocking/clicking noise. Comes when I turn the key to first position. Engine doesn't have to be started. Usually goes by the time I have down the drive!
2nd is all of a sudden sometimes again, when I turn left or right, occasionally my steering wheel, or maybe even indicators makes a beep noise. Not all the time and it only started today. I think it has only happened when indicators have been on. Other than that steering wheel has been a tad more squeaky than usual.
I also wondered if pollen filters been blocked would stop my heating working on settings 1 and 2. Heats up as normal and all that. Setting 3 works, but 1 and 2 don't work at all.
Just done oil change with new filter and rocker box cover gasket as had a bad leak. Changed oil light switch as I had a faulty one too.
I'm new to doing my own car repairs so ain't very technical lol! Help in the easiest way possible would be amazing! Hopefully its simple and easy stuff that I can do myself, need to get it sorted as my son is due anytime! I have a manual if that helps too!
Thanks in advance!
Thanks in advance!
