General noise sounds like wheel bearing failing
saminfrance
Hi All
I am new to the Fiat Ducato
I have a McLouis Tandy Motor Home, 2007, with a 130 Multijet engine
The vehicle has done about 27,000 miles
I have a noise when driving sounds a bit like a wheel bearing, however it has just passed its MOT so unlikely to be that
Any ideas
Thank you in advance
Sam
Had that myself, and would suggest that if you think it might be a wheel bearing then your guess may well be correct. I’m assuming you’re talking about a front wheel bearing, and if so jack up each wheel in turn and give the wheel a good spin. The “feel” and sound difference between a good and bad bearing will be obvious.
Mick
