Ok, well, to cut a long story short, my UT ran fine before i took the box off for a rebuild and swapped my fuel tank over for my alloy one.
Since fitting the new box and tank, i now don't have a spark what so ever. I've had my mate (an Auto Electrician) out and we checked the coil and that was shot. So fitted a new coil and it still didnt work. So, he checked every wire from the ECU to the coil, every wire from the Amplifier plug to where ever that goes, checked all my crank position sensor and other sensors (thers 3 on the UT) and they are all working fine no probs and all the wiring is fine.
So, after checking everything spark related, and checking everything was plugged in and earthed properly, he said that it was either the ECU knackered or the coil Amplifier was shot.
a quick call to wayne (off here) and he said to come try them on his car, so i went up with my ECU and my Amplifier and coil and tryed them on his car. It work perfectly fine with all combinations, my ecu, his coil, his ecu, my coil, both my ecu and coil,and it worked everytime no problem!
so now what the hell do i do?????? i'm completly stuck!! The cars sat there ready for an oil change then MOT and theres nothing i can do to get it going!
is there anything else that will stop the car getting spark? Theres no immobiliser, no alarm so thats out the question. The cars also getting fuel as the plugs are wet and smell of fuel and the engines turning over perfectly well, just no bloody spark! grrrrrrrr
need help ASAP!!!!
any ideas??
cheers from a very desperate Dunc
need help ASAP!!!!
any ideas??
