johnnyonone
- Joined
- Oct 16, 2009
- Messages
- 10
- Points
- 5
Hi, hope you can help.
Any idea on how to remove the aux/usb port from the dash?
Currently getting no power from my usb port but the aux port is working and the lights surrounding both ports are working. Head unit saying no device connected(usb stick for music) and phone not charging. Usb stick and phone cables all working when connected to playstation.
It is not a blown fuse as I have removed the f36 15amp fuse from behind the glovebox, this fuse also works the climate control system and that is working fine.
The only other thing i can assume is that the connector has come loose on the back of the usb port!
£40-45 on Ebay for a new unit but need to check the rear connector first.
Thanks in advance for your time.
