Hey wizk1
Thanks for the info. Will start having the services looked into. I'm actually surprised with the bravo. Was always against having a fiat but this is a good car to drive.
Welcome to the Forum, and nice choice on the Bravo
I have the Tjet 150 sport version, they are surprisingly good cars, they feel solid on the road. Surprising really considering the pace of development of the Bravo in response to the failure of the previous Stilo - they churned out a motor ten times better in half the time
It is the same platform as the Stilo which itself was a pretty good chassis, only letdown on the driving feel is the electric power steering. If you have the sport version then having the sport mode on removes a lot of the electric power assistance which really helps the driving feel, I also have Powerflex polyurethane bushes installed which have really brought the car alive on the road, can really feel the road underneath you but without any compromise in comfort.
I’ve owned my Bravo since August 2018 so not had as much experience with them as the majority of other members here, the only issues I’ve had are a failed wastegate solenoid and new ball joint on the front offside wishbone, I replaced both wishbones and installed the poly bushes at the same time, wastegate solenoid only cost £35 so I’ve had a reliable experience so far.
As yours is at 94k miles your timing belt should have been changed 22k ago at around about 72k miles, does your service history show this? If so hopefully your water pump was changed at the same time.
The Tjet engine is essentially an evolution of previous Fiat FIRE engine designs and are very reliable, just be sure to keep an eye on your oil level and change the oil every 10k as stated.
https://www.fiat-lancia.org.rs/Manuals/Fiat/Nuova_Bravo/Fiat_NuovaBravo_1.4TjetEngine.pdf
If you’re technically minded have a read at the document I’ve linked above, it gives you a lot of information on everything on the Tjet engine.
