Bravo Newbie looking to buy...
Hello FF members, my name is David and I am looking to buy a Bravo Multijet Sport. I have a few questions to follow below....
I hope if I like the car and the deal comes off I will be a regular member on here.
All the best
redpatt:)
1. What are other members real world mpg for the 2.0 Mjet Sport on 18'' wheels
2. What are the tyre sizes, load index and speed rating for the 18'' wheels? Does the car need reinforced tyres?
3. Typical service costs?
4. Common problems?
5. Does the 2.0 Mjet have a DPF?
Hi David,
Welcome - I have the slightly older 1.9 Mjet engine in my Sport, so I can't provide much help, but here's some info that maybe of use:
1. I average 43 in-town, 51 on my mostly motorway commute (traffic heavy) and 48 combined - this on 17's.
2. Again, a 165 owner will confirm but I think you need 225/40/18, with a 92v rating. I'm 225/45/17 91V and my last set were a 94Y, the extra load rating doesn't add anything significant to the cost.
3. I think my last service was about £160 - typically my local Unc. Arnie branch are pretty competitive on servicing.
4. Please see bottom of this post.
5. Yes, it does, and I have heard people reporting issues but again someone with a 165 will be able to correct my ramblings and give you the skinny on that.
======Common Issues======
These are not all issues I've experienced personally, but rather a summation of my observations over two years browsing this forum:
* If it has white dials be prepared to never know how fast you are going (they are difficult to read under most light conditions, but do look bad-ass).
* Check the lights behind the air conn (if air conn and not climate) panel are lit up at both sides - these lights are on regardless of whether the lights are on or not and hence the bulbs fail - doesnt bother most and they will probably fail anyway - mine have - but FYI anyway.
* The clips on some of the wheel nut centre caps can snap and hence the covers come loose - give each one a few taps and make sure none are loose/about to fall off.
* Front badge - casing can crack from stone chips - check.
* Rear badge - boot button and will leak in water - check for pinky colour/discoloration.
* Look under the front of the car and see if the heat shield is loose - on my (diesel) they are very loose and close to the ground and can come apart if grounded out on speed bumps.
* Play a few CD's in the CD player - these can be temperamental - mine only plays some CD's, so take a collection of 80's ballads to any viewing. Remember your car has the B&M Media Player, so this is of little consequence personally.
* The washer fluid hose can leak on the join by the fuse box - open the bonnet and spray the rear (not the front jets or you'll make a mess) and check under the front left of the car for a puddle.
* Lift the carpet out of the boot and check under it to see if you have a toolkit/spare wheel/jack - sometimes these can be missing.
* Check for any peeling on the leather steering wheel/handbrake lever - this is a common issue that I think Fiat will just about accept and fix.
* Listen for any rattles immediately behind the instrument binnacle - a small but common issue is stuff coming loose behind there and flapping about.
* Misting up behind the rear light clusters - this is normal.
* The Bravo has cornering lights - the front fogs come on and off if under 40mph and you turn the wheel/indicate - it mystifies some people, particularly white van men.
* Clunky suspension noises - not an issue I've ever experienced, but believe there to be a common suspension issue.
* If on the test drive the steering feels too light there is a button to the left of the CD Player that adjusts it.
* Under the front of the passenger seat is a cubby hole opened by a lever - many passengers think this lever moves the seat and tug it too hard, breaking it.
Only other thing is the only problems I've ever had have been drivetrain related (flywheel and driveshaft bearing) - I dont think the problems are as common in the petrol variants but listen as you accelerate for any nasty noises.
I will be honest I had a few issues with mine when first purchased - mostly were just due to horrendous luck (fault Bosch plugs, 2x replacement windscreens after stone chips and a mechanics wrench through my radiator by accident). Aside from the drivetrain stuff though its been pretty OK - I've put 30k miles on it in around eighteen months and it's never let me down. Still love the look and feel of the car, although currently toying with a Brera. :yum:
Andysan thanks for the welcome and a great low down on what to look out for.
Having had 6 Alfa Romeo's I just do not like the Golf I am driving at the moment and as nothing in the Alfa range suits at the moment the Bravo in Sport guise feels like a good compromise.
Head on over to alfaowner for all things Alfa related, I am a member there too as dpat. Lots and lots of information about the Brera which is a beauty of a car. Good luck with your decision(y)
I came from a Golf to a Bravo, I had MK IV, then an MK V, then a Bravo 2.0 Multijet Sport, and have now gone back to a Golf VI.
The 2.0 Multijet sport does have a DPF & in mine it gave no end of trouble, and resulted in lots of dealer visits. Mine was a 2009, it had the exhaust valves changed & still had issues. Ride quality in the Bravo is awful after the Golf, even the MK IV is lots better.
The Golf is miles ahead of the Bravo is pretty much every area apart from how it looks.
Interesting points. Each to their own I guess but I am not enjoying the Golf MkV at all, apart from the DAB radio. The car I am looking at is a 2009 so I hope it won't experience the same problems with DPF yours did. Short of being able to run a Giulietta (which I can't) there isn't anything else in the market that interests/excites me but then I am a fool for Italian cars:rolleyes:
p.s. I have just seen your reason for getting rid however. Glad the one I am looking at isn't a red 2009 model..........
Golf's interior is made of chewing gum, I was stunned to see a friend's golf that was only two years old with most of the button icons washed out and black plastic turning grey.
It sucks to be in the UK but elsewhere you can buy a bravo with more gizmos without feeling robbed by the market depreciation. everybody buys the lowspec bravos in the UK to spend less but they don't get to feel the quality of the high end models.
I must admit that i have had severe problems on the Bravo Sport 165. Every so often the car judders and spasms like there is no tomorrow and has even cut out/stalled on me on several occassions. I only bought the car April last year and has spent 10 weeks in the garage:cry:. I was so looking forward to a happy future with my 09 Bravo, but have been greatly dissapointed! I am currently about to go through the financial ombudsman for a replacement car after Fiats after sales was non existent. The car is currently sorned as i refuse to drive it let alone take my 2x children in it!
I would approach with caution as there are a number of people on this site with the same issues that i have had and Fiat are prepared to do nothing about it.
