LadyV said:
Hi Guys
As I said, I'm new to the land of Fiat Coupes, and so really need some guidance
:worship:
I'm after a 20v Turbo - HOWEVER - I need to know the real deal with these cars, and don't want any biased Bull from anyone, I just want the truth, ie, what goes wrong, running costs, etc
Sorry to sound so blunt, but as a woman, some people think they can say anything to me
I've got my eye on one on PistonHeads, and also, going to pay Solo Italia a little visit, to see what they have to offer
Has anyone used Solo Italia, and what was there experience?
Thanks Guys!! :slayer: :worship:
Hi.
1st of all, stay well clear of Solo Italia. He built my 16v tipo engine when he worked at Forza Fiat. I purchased the car after the rebuild, for the engine to wreck its bottom end. £2700 he charged, and after i stripped it was i amazed at the workmanship involved. To cut a long story short, he is a charlaton and best avoided like the plague. He would not stand by the rebuild and made tons of excuses, so don't use him.
What to look for on turbos;-
High Mileage is not a bad thing on the Coupe as long as it has a proper service history. Engine can exceed 200k no problem if looked after.
Turbos will fail if not looked after. problems occur when owners rev the engine from cold or switch off amediately after a run. This cooks the bearings leading to failure.
Exhaust Manifolds tend to crack and cause a ticking noise when idle. They can be repaired, but it is not easy.
Radiators go anywhere between 70-90k.
Thermostats stick causing running problems.
Oil Coolers go but usually its just the pipes which can be changed.
Clutches can wear quickly if car driven stop start hard. Not cheap to replace.
Timing belts need changing between 28-36k depending on how its been driven. All tensioners, and water pump must be done at same time.
HT leads can give trouble.
Wishbones on front suspension wear.
Rear brakes can seize up as well as handbrake in cold weather.
Check the oil pressure when cold and hot on the dial. When cold, it should be at maximun on dial[3bar]. When hot, idle bar should read 1.5-2 bar. Rev engine and it should hit max 3 bar on dial. This shows engine is healthy.
Avoid modified cars with rechips. Seen to many go bang. Look for an unmolested car as standard or near standard as possible. An air filter upgrade is fine as it lets the car breath better and also gives slightly better fuel consumption.
Always run it on 98 ron unleaded like Shell V-Power.
Use a good semi or Synthectic oil but don't use a thin oil. They dont like it. A 10w/40, or a 15w/40 is fine.
Last but not least, check for crash damage. Many Coupes have been crashed. Bonnets secondhand are in big demand, so check the paintwork. A car with a spotless bonnet with above 50k on it has had a respray. Why? Accident?? An honest car will have stonechips and are welcome by me when choosing a new car as i know its not had an "Head on" accident.
Hope this helps you to find your next car. Any questions, let me know. Btw, what colour you after??
Andy.
