Panda (Mk3)  New Panda
Squarist
Scotland
Hello, :)
We have just bought a Panda Cross 4x4.
Has anyone fitted a reversing camera on one of these?
It been done a few times different ways
Here's one solution
I Fitted a android auto unit to my panda and apart from needing to slightly trip the double head dash kit it wasn't too difficult. I took the cables up the passenger door pillar, behind the passenger and rear door top seals and into the boot. I found a small flap hiding a hole to the outside in the centre below the rear door. I was brave and cut the reversing light wire to supply power. the only thing I am yet to work out is where to attach the green hand break wire to If I can sort this out i may be able to get the reversing grid lines to work!!!!!
If you lift up the plastic around the handbrake
10mm socket I believe
Two under the cupholders
Two under little plastic clips
The switch is to passengers side
Just one wire going to it
Wow so many replies, I just hope I have the nerve to do it. I really would like a reversing camera and I would prefer it to be mounted just above the number plate. But then I guess it’s trying to thread the wires to where they need to go. A BIG thank you to all that have offered advice.:)(y)
