Bruce57
- Joined
- Mar 6, 2018
- Messages
- 2
- Points
- 1
Hi folks, My name is Bruce. I have owned a 126 Bis for over 20 years, It has been sitting in a garage for the last ten. I drove it in there after it had been MOTed and serviced, but had the use a newer/bigger car. My situation has changed and it looks like I may have to start using it again. It is covered in dust and the tyres are flat and has some other problems related to lack of use, ageing, and the action of a "mechanic" not aware of this model.
So long as the engine is not seized I am pretty sure it can be brought back to life. Thing is the standard wheels and tyres looked a bit sad, so I got hold of some Cinq Sporting wheels and tyres, they came with a set of bolts. While the wheels fitted, when I tried the bolts they would not tighten; too long or wrong thread?. So I used the standard 126 bolts.
While they could be tightened by standing on the wheel brace and hold the wheels on, I am worried the bolts are not long enough to be safe (car has not been driven on these wheels yet). I am pretty sure alloys need longer bolts, but what size. I though all Fiats had the same thread on the wheel bolts (M12 1.25), but according to the factory manual i have, the front wheels have M12 1.25 bolts and the rear have M12 1.5.
Is this right or is it a misprint? The alloys are a bit thicker than the steel wheels, but they have a steel insert where the bolts go so are not much thicker. Will it be safe to use the 126 bolts? Can I use the Cinq bolts (possibly cut down so they fully tighten), or do I need some new bolts with different threads for the front and back?
Hi again, and thanks in advance for any advice.
