little miss milly
- Joined
- Aug 11, 2015
- Messages
- 11
- Points
- 2
Hi Fiat Forum,
I'm a new member and have no experience of forums so here goes...
Have run classic pandas for 20 years. Current car is made up from an 1100 Selecta 1994 which I converted to manual gearbox using a 750 4 speed box.
Good round town with lower gearing and surprises many as I put 750 badge on boot! It has single point injection + 2 coil packs/no distributor.
Got a little problem though- At speed on motorway, say 60mph, when throttle is lifted off when going down hill, after a few seconds engine cuts out completely. Pushing the throttle has no effect for about 5-10 seconds when suddenly engine leaps into life and continues normally until next lift off.
Also (!) intermittent red injection light comes on for a bit during normal driving - at speed or whilst idling giving lumpy idling.
Plugs were sooty so thought about ignition fault so changed plugs, leads and Lambda sensor (also sooty).
My next plan is to change engine temp sensor in case ECU is thinking engine cold & making mixture rich..
Words of wisdom appreciated and hello to members
Little Miss Milly (my wife's name for the Panda)
