New member and need help
munroe13
I have recently purchased a punto 1.2 8valve ELX MK2 2000 model from my brother for £200 that has some issues, The rad fan is on continuesly the temp gauge does not have a reading but the light is on and it seems to also be causing the car to rev high on idle and have no real control over it. I took the airbox off and it is sucking very hard from the small opening below the butterfly throttle hole. when i cover the whole to only let a small amount of air in it seems to idle ok. I have had the reading on the ecu stating temp sensor swapped over and having the same problem. been told by an auto electrician it could be the ecu to blame?
Please help
