hi guys,
More fix it again noises :bang: i need to pick everyones heads hear, ive had two garages look for the problem and both have said nothing can be found.
ok the problem is very low speed over uneven road and speed bumps im getting loud crunching and knocking sounds on the passenger side. At very high speeds i can feel wheel wobble which is making me very nervious on driving the car as i have two very young children. oldest is 4 and yongest is 2 which is disabled. So you can see why i just dont want to drive the car this way.
I have replaced both droplinks and problem still the same
the drivers side over speed bumps is crunching and squeeking from the spring area again garage says nothing wrong.
also when driving off sometimes at biting point the engine rocks and vibrates though the car but the garage has said its is because of gearbox which ive wrote below
lastly the garage did notice one thing saying my gearbox is worn which is why its crunching in reverse and is slightly stiff selecting gears. Im just wondering if this is a common problem i have had the gearbox oil changed which has made it easier to live with and ive now found a way to select reverse without the crunch by selecting 2nd the straght into reverse. its a 1.4 6 speed.
surely the vibrating at biting point is a engine bracket but im not a expert i can fix most things on a car but diagnausing the problem is a different thing.
hopefully with your help i can get down to the problems and get this car sorted. I tell you what what seems like a good bargain from a independent garage is becoming hell and ive already had the timing belt and water pump replaced at 280 so i might aswell get the car sorted now otherwise i will lose too much.
and to think I told the garage my circumstances and that the car would mainly be used with my kids in the car. they still sold me a death trap.
I really appritiate all the help guys and gals.
