Technical Need Help Ducato Gearbox 1.9TD 1995
articpt
Lisbon
Hello
I really need some help with Gearbox and Codes for my Ducato.
I bought a Ducato Motorhome 1.9TD 230 1995, seller told me that had all maintenance, and I did only 500 miles until gearbox seized without oil in it.
I dont know what gearbox I originally had, because the one in there isn't the original one.
I only know some codes that are in the gearbox, like TI 07756-211 and M2 9431285021. There ins't a plaque with gearbox code.
It's hard to find a 1.9TD gearbox. I am finding some 230 1.9d gearbox.
Can someone help me with compatibility of different gearbox?
I am finding used 20KE15 from 1.9d... only one 20KE02 and very expensive... I dont know if they are almost the same...
Fiat ePER says on compatibility
M1 - M 1930 DS
M2 - M 1930 TD
M3 - M 1930 TD CAT
But dont say nothing about gearbox codes I think.
If someone cay give me some help I would be very thankful.
Chassis ZFA230
Only a suggestion but some Peugeots, Citroens,Talbots and maybe Renaults had badge engineered versions of those vans.
Also several cars ran that engine, though I have no idea if gearboxes different in the vans apart from axle ratios etc. which may be another problem as not low geared enough for the loading.
Are any of those makes of van still in regular use where you are, though at nearly 29 years old it may be pushing it a little.
I believe there are some companies in this country who specialise in parts for older campers that Forum Members can advise on.
Mine is a 20KE22
The one I saw to buy is a 20KE02
Dont know if they match?
Hello,
I have exactly the same problem as you, what did you do finally ?
