need an amp this guy sells loads ebay
Essex/Suffolk border
http://www.stores.ebay.co.uk/allyourbassuk/plistings/list/all/dept0/index.html?col=2&dir=-1
from 300w max to 2600w max, usaly they go for under a ton and thats the big ones, you can get up to five for the same postage so if your mates won't one as well you can get a real bargain.
the little 300w ones go for £25 £30
<blockquote id="quote"> face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by dave
<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
GOOD ONE!! :D
Is adrenaline brown?
i think it is lagit, have been using ebay for a while, but they arn't the best quality amps at all. cant say what they will do but probably not last the longest and secondly mabey give a bit more distortion then other.
and he said to his himself, "wow! what was that thing, it went like a blurr. I wish I had a Punto".
---Clayton---
well at the min i got a 300w amp and a m8 of mine mite sell his 350w 2x12" subs to me but we tried em they blew the fuse in my amp with was a 30amp fuse so tat pritty hight but a 30w amp should just cut out if i try and turn it up to much shouldnt it?
gotta love the uno's
I don't know what you mean by cut out if I turn it up much?
I think that as the speakers can take collectivly a lot more then the amp can give, then the amp wont cut out if you turn it all the way to maximum, however you will get distortion, engine noises and probably blow the fuse this way.
try a 40amp fuse in you amp with the gains on about 60% or under this should then leave you to play with the head unit hopefully with nothing going wrong.
---Clayton---
ta m8 now ive brought 3 more 30amp fuses now he tells me! the amp is not on maximum its about half way and if i turn hte volue past about 22-23 the bass cuts off n im just left with the 6x9 playing!
My son got a shark amp off that guy on ebay in september and it ain't gone wrong yet but it says its 600watts rms 1600watts power but some people say that the real rms is only half thatB)
Please do not Email or PM me asking for support. Post on the forums instead. Your reply may help someone else. Thank you
Amp cutting out? Has it got overload protection?
Turn the gain right down with the radio off. turn it on, put turn it up to the point where the main speakers START distorting, then alter your bass to the point it cuts out then.
Your amp might be being overloaded by trying to run it too loud at a low volume...set it to cut out at a volume too loud to listen to!!! .............Thats how I did mine anyway.
Arse
Ill think of something witty....just wait and see............wait I might not.
